Jules Monique Pre Amp`s Reklamtråd
- Elfström
Jules Monique hanbyggda preamp´s i världsklass!
Tillgängliga för test och leverans under sommaren.
Första exemplaret i rack format dyker upp under Juni.
Dove Cage modellen i metall kommer lite senare under sommaren.
Det är samma innehåll i alla modellerna, endast format och finish skiljer.
Edit. Inga cirka priser än pga. att fraktkostnaden inte går att beräkna på ett bra sätt, före första leverans.
Det finns kundpris på Jules hemsida om man vill försöka estimera själv: http://juleamps.com/shop/index.php" onclick="window.open(this.href);return false;
Shut up and play yer guitar!
- Elfström
Re: Jules Monique Tråden
- Elfström
Re: Jules Monique Pre Amp
Monique has two separate outputs for Balanced XLR and 1/4" Line Out. Both are entirely separate and adjustable. The XLR is driven by an astounding Cinemag transformer. A wonderful sound in the studio.
Monique has a studio quality low noise level. She is also great live on the stage, no matter what amplification you find yourself with.Monique has two outputs: Line Level output (1/4" Single Ended TRS) and a separate XLR balanced DI output that is driven by a beautiful Cinemag transformer. Both outputs have their own separate level controls. The Line Level control is also a push-pull switch. Left in, the Line Level control gives you the original Monique (0db .775volt) output. When you pull the Line Level control out you get a 4db increase in both the Line Level and the Balanced XLR outputs.
That gives you up to (+4db 1.25volts) from the Line Out and (-10db .775volts) from the Balanced XLR output.
The Line Level Output often goes directly to the input jack of your amplifier, but it's 10K output impedance also hooks up extremely well to an Effects Loop Receive, a Power Amp Input, or a Line Input jack.
The DI Balanced XLR output will keep your most critical studio engineer extremely happy.
The three phase EQ of the Monique is a Baxandall, similar to that used in the Ampeg SVT. This EQ gives you 20db plus and minus from the center of each control. This also means that this is a non-interactive equalizer.
- Basmagnus
- strummer
- bassace
Undrar varför de vänder på EQ-kontrollerna, åtminstone jämfört med alla stärkare jag använt, High till vänster och Low till höger?
~ banden jag spelar i ~
https://goingbig.se
https://greatnorthern.se
https://goingbig.se
- strummer
Samma som GK och Aguilar, som det ska vara alltså:-)bassace skrev:Undrar varför de vänder på EQ-kontrollerna, åtminstone jämfört med alla stärkare jag använt, High till vänster och Low till höger?
Kompressor, det är livet!
- Elfström
strummer skrev:Samma som GK och Aguilar, som det ska vara alltså:-)bassace skrev:Undrar varför de vänder på EQ-kontrollerna, åtminstone jämfört med alla stärkare jag använt, High till vänster och Low till höger?
- JonnyTrobro
Jag har en Dove Cage, äckligt bra ljud!
- Elfström
- JonnyTrobro
Ja det dräller väl inte av Moniques i Sverige [FACE WITH STUCK-OUT TONGUE AND TIGHTLY-CLOSED EYES]
- Elfström
Ännu.....JonnyTrobro skrev:Ja det dräller väl inte av Moniques i Sverige [FACE WITH STUCK-OUT TONGUE AND TIGHTLY-CLOSED EYES]
- Håcke
Vad kostade den?JonnyTrobro skrev:Jag har en Dove Cage, äckligt bra ljud!
- JonnyTrobro
1628 USD plus tull och moms.Håcke skrev:Vad kostade den?JonnyTrobro skrev:Jag har en Dove Cage, äckligt bra ljud!
- hitman
De fick lysande recensioner i Bass Guitar Magazine, dock noterades att de var dyra.
VÅGA VÄGRA VOLVO !!!
- JonnyTrobro
Kvalité har alltid kostat mer, även om vissa basforum har svårt att inse detta.hitman skrev:De fick lysande recensioner i Bass Guitar Magazine, dock noterades att de var dyra.
- strummer
Jag har testat en hel del, och det är helt klart en sanslöst bra preamp. Tonkontrollerna är ruggigt effektiva, men det jag blev allra mest imonerad av var sensitivityratten:-)
- bootsy
- JonnyTrobro
Sensitivity är magisk, allt från rent till fett och mättat. Jag har alltid varit smått beroende av kompressorer, men efter att jag skaffat en Monique spelar jag mer och mer utan. Rörkompression is the shit!strummer skrev:Jag har testat en hel del, och det är helt klart en sanslöst bra preamp. Tonkontrollerna är ruggigt effektiva, men det jag blev allra mest imonerad av var sensitivityratten:-)
- strummer
Så långt har jag inte ens tänkt, jag är ju total kompressorjunkie haha:)JonnyTrobro skrev:Jag har alltid varit smått beroende av kompressorer, men efter att jag skaffat en Monique spelar jag mer och mer utan. Rörkompression is the shit!
- JonnyTrobro
Samma här, kompressorer är lika intressant som basar!strummer skrev:Så långt har jag inte ens tänkt, jag är ju total kompressorjunkie haha:)JonnyTrobro skrev:Jag har alltid varit smått beroende av kompressorer, men efter att jag skaffat en Monique spelar jag mer och mer utan. Rörkompression is the shit!
- Elfström
Fick den här frågan i Zon tråden....
Jag har dessvärre råkat sälja det första exemplaret lite för snabbt, som var första leverans.
Det skulle kommit till ca. slutet på Maj....
Jules försöker stampa fram ett till exemplar så snart det är möjligt... ?
Troligen går det att få prova i början Juni eller något tidigare, med lite tur.
Svarar här i "rätt tråd"!TG skrev:Ser läcker ut. När kan jag prova denna!Elfström skrev:Ny preamp kompis, Jules Monique!
Mer Monique i en egen tråd:
http://www.pratabas.se/viewtopic.php?f=2&t=76975" onclick="window.open(this.href);return false;
Jo! Gear for the average bass player...
Det enda som är snyggt på bilden är ju Monique och mustaschen på Chris Cardone (president för Circle K strings)...
- Elfström
Läs själva, här är artikeln:hitman skrev:De fick lysande recensioner i Bass Guitar Magazine, dock noterades att de var dyra.
Jule Monique All Tube Bass Preamplifier by Jake Wolf
MAY 1, 2012 BY JAKE WOLF 2 COMMENTS
"Jule Monique All Tube Bass Preamplifier by Jake Wolf… When I first unearthed the Jule Monique from its shipping box, I wasn’t sure what I was getting in to. At first inspection, it appears gorgeous; a bamboo wrapped, cleanly executed tube-laden symphony of quality components and luxury fit/finish. Then, as my wheels of practicality and pragmatism started turning, I started looking at this sizeable, relatively expensive, preamp-only device, and I couldn’t help but wonder if, with today’s cornucopia of great sounding micro heads and stompbox preamp/DI’s, is there really a niche/need for this beast? I’ve played through and owned a lot of tube preamps over the years, in my quest for bass tone nirvana. On the whole I’m a big fan of the warmth and textural depth that tube circuits often bring out in my sound. As I waited for the Monique’s tubes to warm up for an initial listen as the front end of my rig, I was thinking; “This thing better really bring the heat”. After about 2 minutes of testing, it was evident that Monique might just be the pinnacle of impeccable, studio-grade tube tone for the bass world.
Monique was designed as both a studio direct box and a tube front end for live rigs, in the spirit of classic bass heads like the mighty Ampeg SVT. With Monique’s huge and defined tone, super low noise floor and powerful EQ, she excels at both. While many bassists covet the tone of their all tube heads, they rarely covet the size and weight that accompany it. As many working pro’s find themselves flying all over the map to gigs and sessions, one can see how having a portable device that can offer similar tone and feel to their beloved tube head is becoming increasingly practical and desirable.
The front panel of the Monique is simple and effective. A knob labeled ‘Line Level’ acts as a master volume control for the ¼’ output, and a powerful 3 band ‘Baxandall-style’ EQ allows for broad tone shaping with 20db of cut/boost per band. The ‘sensitivity’ knob is where things get interesting. As you turn the knob clockwise from zero, as Jule puts it, “You hear more from Monique”. Set closer to zero, Monique sounds clean and precise. The more you crank it up, the more grit and growl comes out of the unit, and the more dynamically expressive it becomes. Dimed, it definitely starts to resemble an overdriven tube amp. Additionally, the Sensitivity knob has a pull function that adds 4 db of headroom, designed to optimize its use with passive basses. The rear panel features two discrete outputs: The ¼” unbalanced output is intended to drive the front end of an amp, but I found it will also adequately drive a poweramp (or for that matter, an effects return/power amp input on a bass head). The transformer driven XLR output level is set by the volume knob on the rear panel.
As it turns out, I managed to answer my own question “is there really a need/niche for this beast?” by observing my own behavior. As someone with great sounding gear, who is constantly consolidating my live rig to be as small/light/easy as possible for regular gigging, I was sort of surprised to find that I’ve been bringing Monique everywhere I play. Every time I plop her on top of my rig, no matter what style of music I’m playing, (whether it’s in front of my micro head on stage, or in my audio chain in the studio) she imparts the kind of depth, weight, and syrupy cohesion that makes me instantly grin. Band members remarked after about 30 seconds of listening that it was easily the best they’ve ever heard my bass sound. Even if you’re not a ‘tubey’ SVT kind of guy (which for the record, I typically am not) you really cant deny the sound coming from this unit. Since describing subtle audio nuance is futile at best, I will just leave it at this: Very rarely do adjectives like ‘quick’ and ‘effortless’ go hand in hand with ‘phat’ and ‘massive’. But Monique does her thing without adding any bloat or blur, kind of like (pardon the automotive parallel) an 18 wheeler that can do 0-60 in 4 seconds. If you think you know what tube bass preamps can and can’t do, Monique may make you eat your words. Monique’s spirit reminds me more of a high-end studio channel strip than a “tube bass preamp”. There’s a level of sophistication and panache in Monique’s appearance, build quality and tone that’s rarely found in the bass realm, and therein lies her niche.
The Jule Monique is available in bamboo for $1700, or with a metal frame for $1300, sold direct from the builder, Jule Potter of Jule amps. In his small California workshop, he hand crafts a luscious array of boutique amps and preamps. Check him out online at http://www.juleamps.com" onclick="window.open(this.href);return false;.
- JonnyTrobro
Så här kan Monique låta
[spotify]http://open.spotify.com/track/6Pwhp5U2huw1IeO9NDysWv[/spotify]
