[phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 483: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead
[phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 112: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead
[phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 4685: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3815)
[phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 4687: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3815)
[phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 4688: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3815)
[phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 4689: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3815)
Basrigg-FAQ • PrataBas
Basrigg-FAQ
Re: Basrigg-FAQ
Inläggav Phear » ons 20 aug 2014, 15:54
Nej tror inte det. 2, 8 och 32 ohm är väl de alternativen som finns (med reservation för ev. kortslutning i min hjärna)
Phear
Re: Basrigg-FAQ
Inläggav Anders » ons 20 aug 2014, 18:09
Tack för svar.2Ohm skulle vara bra.
Fender American Standard Precision V
Ampeg SVT Cl,AmpegV4BH,
TKS212,Tecamp M115
Anders
Re: Basrigg-FAQ
Inläggav fieldflower » ons 20 aug 2014, 18:17
2 Ohm går fint.
Är lådan på 8 Ohm lär det vara 8 Ohms element i den - 2 serier som är parallellkopplade.
Om du istället parallellkopplar samtliga element blir det 2 Ohm.
Ena ingående tåten till + på samtliga, och andra ingående tåten till - på samtliga. Svårt att göra fel.
Medlem i PB40+
Bandet:
Re: Basrigg-FAQ
Inläggav Anders » ons 20 aug 2014, 22:04
Guld! Tackar och bockar fieldflower.
Anders
Re: Basrigg-FAQ
Inläggav BillWyman » ons 19 nov 2014, 21:31
Varmt tack för att Du tog dig all den tid det måste tagit att skriva en sådan här fantastiskt intressant, välskriven och informativ text, (som dessutom är hållen i en varm och trevlig ton) tks!
Ditt resonemang runt två likadana lådor låter sunt och logiskt i mina öron. :-)
Fender: AM Std Jazz (fretless) - AM Std P-Bass - AM Deluxe Jazz.
Ibanez: SRF 700 Portamento.
Maruszczyk: Jake L 4p Classic.
Ampeg Micro VR + Ampeg SVT-210AV x 2
Quilter Bass Block 800 + TKS 1126
Pedaler
BillWyman
Re: Basrigg-FAQ
Inläggav demoncleaner » tis 08 sep 2015, 14:58
Den här tråden är ju underbar. Har lagt en halv arbetsdag på att läsa igenom, väl investerad tid! (Berätta inte för min chef bara.)
demoncleaner
Re: Basrigg-FAQ
Inläggav robinmag » tor 28 jul 2016, 11:11
Har jag förstått rätt; två stycken 8 ohms lådor ska gå ut från 4 ohm på toppen? Om jag kopplar en 16 ohm och en 8 ohm, vad blir det då från toppen? Detta är nytt för mig, så jag erkänner mig okunnig :)
robinmag
Re: Basrigg-FAQ
Inläggav BBQV » tor 28 jul 2016, 11:52
Den här kanske hjälper?
Re: Basrigg-FAQ
Inläggav robinmag » tor 28 jul 2016, 12:09
robinmag
Re: Basrigg-FAQ
Inläggav bjelkeman » tor 28 jul 2016, 13:32
Ibanez () & Warwick, Darkglass, TKS. Mina besök hos och .
Re: Basrigg-FAQ
Inläggav robinmag » tor 28 jul 2016, 22:52
Tack för hjälpen!
robinmag
Re: Basrigg-FAQ
Inläggav Johan » tor 18 aug 2016, 17:55
Reidmar 750, Proline 410, MattissonBass Serie IIc med många strängar.
Johan
Re: Basrigg-FAQ
Inläggav fieldflower » tor 18 aug 2016, 23:08
Re: Basrigg-FAQ
Inläggav Johan » tor 18 aug 2016, 23:18
Det här låter spännande.
Ska undersöka saken i närmaste musik affär, om det är möjligt.
Annars får det bli på nästa pratabas träff.
Johan
Re: Basrigg-FAQ
Inläggav fieldflower » tor 18 aug 2016, 23:27
Det går ju teoretiskt att koppla om din existerande låda till 16 Ohm och testa om du kommer upp i samma ljudtryck ändå.
Det blir liksom samma sak då lådan då får max 175 W.
Låter det bra och kommer upp i tillräcklig volym kommer nästa låda bli ett lyft.
Men det är ju lite pill att koppla om, så man vara bra sugen på att få veta för att göra det...:lol:
Re: Basrigg-FAQ
Inläggav gthyni » fre 19 aug 2016, 01:05
Fast det är inte så enkel, dubbla effekten ger faktiskt bara en marginell ökning av max volym, medan dubbla konarean flyttar mer luft. Svårt att säga exakt utfall utan att testa hur man upplever det
Tokai Hard Puncher 1980
G&L L-1000 "Wunkay" 1985
gthyni
Re: Basrigg-FAQ
Inläggav fieldflower » fre 19 aug 2016, 10:29
Re: Basrigg-FAQ
Inläggav Johan » lör 20 aug 2016, 23:28
På MusicMusic i Örebro fanns ej kablar att testa seriekoppling av 2st 4ohms lådor. Tyvärr..
Det fanns dock 3st olika 8ohms lådor, det fanns inte ens kablar i butiken så jag kunde testa 2 av dessa tillsammans.
Med 1 st 8ohms låda (ampeg 410h) så fick jag sätta volym ratten på ca 2,5 innan lådan började flytta luft .. vid 3 så började den "prutta" när jag spelade på låga F# till A
Låga B och uppåt lät fortfarande bra.
Johan
Re: Basrigg-FAQ
Inläggav gthyni » sön 21 aug 2016, 08:23
Olika lådor har olika egenskaper. För att få en idé om svaret på din fundering så bör du testa med 1 resp 2 lådor av en modell som du tycker låter bra. De flesta baslådor är inte optimerade för frekvenser utanför vad en vanlig EADG-bas använder
gthyni
Re: Basrigg-FAQ
Inläggav Punkster » sön 16 okt 2016, 21:18
Jag har en liten fundering. I specarna för min Peavey fyrtia så står det:
350 watts (rms) continuous
700 watts (rms) program
Vad innebär det och vad är skillnaden egentligen? Min topp är på 700w, och det vore ju bra att veta hur mycket man törs kräma på utan att riskera att blåsa ut elementen.
/Linus
Punkster
Re: Basrigg-FAQ
Inläggav fieldflower » mån 17 okt 2016, 09:20
Re: Basrigg-FAQ
Inläggav Roger Hedin » tis 20 dec 2016, 13:18
- Ron Carter
Re: Basrigg-FAQ
Inläggav midlifecrisis » tis 20 dec 2016, 23:32
Har funderat på att lägga till en låda till min rigg som nu utgörs av en V-4B och en Pro Neo 115. Det väger mellan ytterligare en 115 eller 210. Vad finns det för pro or cons mellan dessa alternativ?
-Freddie Mercury
midlifecrisis
Re: Basrigg-FAQ
Inläggav peter_s » tor 22 dec 2016, 22:22
peter_s
Re: Basrigg-FAQ
Inläggav midlifecrisis » fre 23 dec 2016, 03:15
midlifecrisis
FöregåendeNästa
Återgå till Förstärkare
Vilka är online
Medlemmar online: Basmasen, Bing [Bot], ferm, Google [Bot], Google Adsense [Bot], Hugo Drax, pellesanslös
