Klass d-slutsteg, vad finns?
- Grafen
Finns det några rena slutsteg i samma smidiga format som de flesta småtoppar? Rackslutsteg är lätta att hitta men jag är ute efter maximal portabilitet och åtminstone 2x250w i 8 ohm.
Stallet är hendekagonalt.
- 200071
Re: Klass d-slutsteg, vad finns?
Jag har en SWR Amplite....
Du har ju de här, fast du behöver två om du ska köra stereo:
http://www.bose.com/prc.jsp?url=/shop_o ... p&color=bl" onclick="window.open(this.href);return false;
Jag har två, en Demeter Minnie 800D och en Jule Amps 700M. Båda fungera mycket bra tycker jag.
- Elfström
There is no Class D Amplifier like the Hypex Amplifier when we are looking for outstanding response from the highest to the lowest notes you choose to play. There is also no amplifier that delivers the power you want like the M700. You will find notes and you will find new places to play, not only in the middle ranges where the speed of this amplifier shines, but also at the top and the bottom of your tone range.
Much of the power delivery of the M700 is related to the over-built power supply that keeps the amplifier going. This power supply is optimized for 4 ohms, but it will deliver 1200 watts for relative short sessions into 2 ohms. All that means that you will never run out of power no matter how low that top string is.
The chassis measures 12" x 12" and is 4.5" tall including the feet. It weighs one pound for every hundred watts it delivers. 7 pounds.
The chassis is made of all aluminum so that it is a very effecient heat sink. You will not overheat this amplifier.
There is no quieter 700 watt amplifier anywhere. No hiss. No noise. Not until you want to make your music.
Please understand that the M700 truly delivers 700 watts of power. If you hope to use a cabinet that only handles 700 watts for short durations, it is going to be up to you to either keep the volume within the range of your cabinet, of face the real possibility of cooking your speakers.
Shut up and play yer guitar!
- Fredde79
Rekommenderar absolut Hypex, speciellt om man inte är rädd för att bygga lite, kostar inte skjortan heller. Har själv byggt kring deras UcD2k modul:
http://www.pratabas.se/viewtopic.php?f= ... 0#p1286271
Mer detaljerad beskrivning här:
http://www.diyaudio.com/forums/instrume ... ost4409691
/Fredde
- Fender Jazz 1973
- Fender Jazz 1973
- gthyni
$1375 för ett klass-D-steg är sanslöst.
