Marshall DBS7200 transistorstärkare i toppskick säljes
200w med rör i försteg.
har stått oanvänd i flera år.
case ingår. pris 3500:-
NU PRISSÄNKT. 3000:-
Marshall DBS7200 prissänkt!!!!!!!SÅLD
- Tomas
- Marshall
- Tomas
Jorå ett ECC83
utdrag från marshallamps:
Heritage >Dynamic Bass System > 7200 I 7400 I Combos I Rigs
Unbelievable levels of clean power from our unique extended dynamic headroom circuitry, plus superb control and comprehensive facilities are what you'll find in the 7200 Dynamic Bass Amplifier head.
The Dynamic Bass principal involves using more than the single power supply found in conventional bass amps. This means that when incoming signals, too dynamic for a normal bass amp to handle are detected at the input stage, the extra power supply automatically engages to handle them cleanly. This provides the 7200 with the energy to pump out 2000 watts of peak power from it's 200 watts RMS power stage, giving you five times more headroom than the typical bass amplifier.
The resulting system will respond to whatever dynamic range you can throw at it, delivering the tightest, punchiest bass response in even the most demanding playing situations.
The single ECC83 valve in the pre-amp ensures responsive warmth and musicality from the superb quality tone shaping provided by the pre-amp section.
