Selmer Rör-rigg i DAGIS-STUK - Blocket
- bic
- Diesel
- bic
THE TREBLE N' BASS 100
Lite engelska skadar väl inte.
I dag är saxofoner det man kommer att tänka på när man hör ordet Selmer men på 60 och 70-talet var utbudet ett helt annat.
http://www.vintagehofner.co.uk/selmer/black/sel4b.html
Almost as though a cuckoo had landed in Selmer's nest, this monstrous chick appeared in quite different plumage to it's other blue/black nestlings. It's all-metal case design was shared by the Stereomaster and the TV100 PA, which appeared at about the same time. They probably arrived just before the blue/black period, as we have found a Selmer advert showing them amongst croc-skin amps, where they look even more out of place. The design was way ahead of its time, and bears more resemblance to rack-mounted gear of a much later era than the mid-60's.
Described as "one of the most powerful amplifiers ever produced", it has two channels. Bass and Normal - the latter having tremolo. Valves - 4 x EL34, 2 x GZ34, 5 x ECC83. Size - 19.5" x 11.75" x x8.5", and priced at 82 gns. eller 23 kg
Recommended speakers were a pair of All Purpose 50's, two Goliath 50's, or a single Goliath 100.
