Fender Rumble 210, 500w [såld]
Busta B
Inlägg av Busta B »
Hej,
Säljer min Fender Rumble. Fint skick - inte en repa. Endast replokalsspelad.
Inte min bild.
Pris såld!
Class D
Power: 500 W
Loudspeaker: 2 x 10" Eminence ceramic magnet speaker with 4 ohm
Compression tweeter with on/off switch
1 x thomann Channel with switchable bright switch
Contour, vintage switch and overdrive
Controls: Gain, bright on/off, contour on/off, vintage on/off, drive, overdrive on/off, level, bass, low mid, high mid and treble
6.3 mm jack input
Headphone connector
Mini jack stereo AUX input
Line out XLR with Ground Lift
Effects loop send and return
External speaker output minimum 8 thomann Ohm
Ivory soft touch radio potentiometer knobs
Dimensions (H x W x D): 58.4 x 48.2 x 35.5 cm
Weight: 16.56 kg
Busta B
Re: Fender Rumble 210, 500w
Inlägg av Busta B »
Upp!
ursus
Inlägg av ursus »
Byte mot en Streamliner 600?
All you need is funk
Busta B
Inlägg av Busta B »
Såld!
