Liten och smidig, med massor av funktioner och inställningsmöjligheter.
Utmärkt skick. Finns i nordvästra Skåne för test och hämtning, men kan skickas i originalkartong.
Tillverkarens sida:
http://www.taurus-amp.pl/bass/head/bass ... e-300.html" onclick="window.open(this.href);return false;
SÅLD
Info/specar på utrikiska:
Power output: 300W RMS / 4ohm , 200W RMS / 8ohm
Main Features: analog preamp / PA class-D / SMPS
Inputs: passive & active
Controls:
GAIN control
VOLUME control
BASS and TREBLE equalizer with "MLO system" (Middle-range Level Optimization).
Triple BASS-switch to reduce or boost low frequency [DBS-cut/OFF/DBS-boost]
Triple TREBLE-switch to reduce or boost high frequency [CUT/OFF/PRESENCE]
PUNCH button - increases sonic expression. Two different sound modes available Punch-1 and Punch-2
MLO EQ - TECH INFO:
BASS: 40Hz +/-10dB @400Hz -/+4dB
BASS Boost/Cut: 60Hz +/-6dB
MIDDLE: 2kHz +7dB / 550Hz -7dB
TREBLE: 6kHz +15dB / 8kHz -15dB,
TREBLE Boost/Cut: 6kHz +8dB/-10dB
PUNCH Low (A): 300Hz +6dB
PUNCH High(B): 950Hz +6dB
Other features:
MUTE button
CLIP indicator
Protections: short circuit, thermal overload, power overload
Forced cooling system
Casing dimensions: [H x W x D] 66x200x155mm
Overall dimensions: [H x W x D] 66x200x180mm
Weight: 1.7 kg
SÅLD - Taurus Qube 300 - SÅLD
- engson
- engson
Re: Taurus Qube 300
Nytt pris: SÅLD
