Verellen Meatsmoke *såld*
viktro
Inlägg av viktro »
Verellen Meatsmoke, 2 generationen med separat EQ för varje kanal. Preamp för bas och ev gitarr med endast rör. Svinbra grej, men jag säljer för att finansiera annat. Använd på en handfull rep och ett par gig, nära nyskick. Finns i Midsommarkransen, Stockholm.
Pris: 5500.- kan säkert skickas.
2018-09-13 09.22.52.jpg (33.8 KiB) Visad 1382 gånger
2018-09-13 09.23.11-1.jpg (41.23 KiB) Visad 1382 gånger
2018-09-13 09.23.24.jpg (36.41 KiB) Visad 1382 gånger
The MEATSMOKE dual channel preamp is voiced for bass guitar or huge guitar sounds, and features the MEATSMOKE's unique overdrive boost.
Complete with Gain control, 3-band EQ, and Master Volume controls per channel. High and Low output modes allow for instrument-level use with a standard guitar or bass amplifier, or run directly into a power amplifier. Running one of the PREAMP PEDALS into an effects loop return or the power amplifier input of a bass or guitar amp can completely transform the amp's sound.
The dedicated record output includes a speaker simulating filter with two levels of intensity. This allows for running the PREAMP PEDALS directly into a mixing board, tape machine, or DAW, without the need for heavy power amps or speaker cabinets.
2 footswitchable channels complete with independent Gain control, 3-band EQ, and Master Volume controls per channel. Clean channel ranges from big cleans to growl, while the overdrive channel picks up where the clean channel left off going from crunch to all out thick distortion roar. Foot-switchable true-bypass switching also allows for stompbox-like functionality.
Housed in a sturdy black steel enclosure, set between two side-panels of finished birch. High-quality components are used throughout, including a regulated DC filament supply. Careful shielding circuitry layout yield huge tone with a low noise floor.
info:
https://verellenamplifiers.bigcartel.com/" onclick="window.open(this.href);return false;
viktro
Re: Verellen Meatsmoke *Prisbump*
Inlägg av viktro »
Prisbump: 5500.-
