Helt ny Taurus Ts-10
Pris - 6500:- inkl frakt
Power output: 350W RMS / 4ohm , 200W RMS / 8ohm
Speakers configutarion: 1x10” 8ohm Neodymium + switchable ceramic tweeter
Cabinet sensitivity: 97dB@1W/1m
INPUT - passive & active
SIGNAL LEVEL:
GAIN control with overload LED
VOLUME control
TONE:
BASS and TREBLE equalizer with “MLO system”
Triple BASS-switch to reduce or boost low frequency
[DBS-cut/OFF/DBS-boost]
Triple TREBLE-switch to reduce or boost high frequency
[CUT/OFF/PRESENCE]
PARAMETRIC EQUALIZER - provides extra precise control over middle frequency band [120Hz-4kHz]
PUNCH button - increases sonic expression
Equalization info:
BASS: 40Hz +/-10dB @400Hz -/+4dB
MIDDLE: 2kHz +7dB / 550Hz -7dB
TREBLE: 6kHz +15dB / 8kHz -15dB,
PUNCH: 300Hz +8dB
Additional features:
MUTE button
CLIP power amp control
Preamp PEAK indicator
Switchable tweeter
XLR balanced LINE-OUT with PRE/POST selector and ground lift
SPEAKER-OUTPUT for additional speaker cabinet (8ohm)
Protections: short circuit, thermal overload, power overload
Coating: polyurethane-hybrid elastomer
Dimensions: [H x W x D]: 400 x 410 x 335 mm
Weight: 12,5kg
Taurus TS-10
Taurus TS-10
