FENDER Marcus Miller - signatur
Tarzan08
Inlägg av Tarzan08 »
Oj!
Såhär skriver man på gear-review.com
Marcus Miller is considered one of, if not the best contemporary bass players, having played with countless big name acts such as Miles Davis, David Sanborn, Luther Vandross just to name a few and also has a successful solo career
To his credit he has two Fender Signature Bass models, an American made 5-string which has recently been released and a Japanese made 4-string counterpart, which has been in production since 1998, this resembles the instrument Marcus uses. The 4 string is the instrument we will be reviewing.
The Bass itself is based on a 1970s Jazz bass, with an ash body, but gone is the usual bridge and “ashtray” cover as this is replaced by a more up to date Leo Quann Badass II Bridge.
The mid pickup cover remains though as this is an essential element is Marcus’s playing style.
This is no ordinary Jazz Bass though, as extra controls and a preamp have been added to make the instrument active or passive at will. The pickguard has also been extended to hide the extra electronics.
Each pickup has its own independent volume control via two knurled chrome knobs whilst two Jazz Bass plastic knobs controls the overall treble and bass. A small switch also turns the preamp on or off.
The pickups themselves are single coil Jazz Bass American Vintage as found on Fenders USA Reissue Series.
Visually the bass is very attractive with lots of grain from ash body showing through the polyurethane finish. The maple neck has 20 medium jumbo frets and is adorned with white square pearl inlays and is also bound in the same colour. All hardware is chrome and the tuners are the correct period vintage reverse tuners.
The tone is well exactly what one expects pure Marcus! Bright and snappy in the higher registers yet deep in the low ones. The preamp also adds extra tone and volume when switched on.
Playing with the pickup cover at first takes a bit of getting used to, it can be easily removed but it adds so much to the character of this instrument that at least for now its staying on!
As final note the finish on this bass is excellent, very impressive for a “Made in Japan” instrument that some consider inferior. The only thing I would have preferred is if it had come with a case though as I had to purchase one separately and these can be rather expensive when bought separately.
Overall a great instrument, which fantastic tone, and an excellent finish.
By Ernest H Slade
Bilder och jox hittar man här...
http://www.gear-review.co.uk/reviews/mm/index.html
Gitarristen i bandet råkade visst köpa in den här på en auktion och tog med sig den till spelningen igår för han ville höra vad jag tyckte.
Jag personligen tycker att det här med J-halsar är ett litet problem, för de är ju så jäkla smala. Särskilt om man lirar på en Roger Waters-signatur annars som påminner om en pizzakartong i jämförelse.
Ljudet... oh, ljudet!
På Engelen lirar man nu för tiden genom en SVT 450 och en 6x10... jösses vilken punch när man kör i fet-läget! Ändå låter det sådär tydligt Marcus Miller så man nästan häpnar. Jag hörde mig själv göra fler än en slap-rusning bara för jag blev så inspirerad av soundet!
En annan personlig iakttagelse är det här med att den är "bara" klarlackad. Jag hade nog gärna sett nån sorts färg på den. Jag tycker att det ser ut lite som en skärbräda eller ett ofärdigt objekt när det inte finns färg på grejerna. Bortsett från den pyttelilla detaljen är det en FANTASTISK bas... Har ni inte testat så gör det!
Vägrar använda smileys!
{fyra strängar}
Mr Praline
Inlägg av Mr Praline »
Grym bas, ja. Väldigt prisvärd. Hoppas bara inte halsfickan på din är likadan som på bilden ;)
BlueFruit
Re: FENDER Marcus Miller - signatur
Inlägg av BlueFruit »
Finns den inte i fler färger?
Jag vet att den femsträngade finns i lite olika kulörer.
"Edit" Jo.
groovyjr
Inlägg av groovyjr »
Det där är över lag en bra jazzbas om man står ut med p-skyddet och att de flesta jag testat varit förbaskat trögspelade trots att de varit justerade. Hade själv en SB och kan inte sätta fingret på vad det är men de känns jobbigt jobbiga och tungspelade till skillnad från de 77-original jag testat. Men som sagt väljudande och med mycket möjligheter.
Ska man sedan vara ärlig så är logon väldigt felplacerade men det är ju the Fender Way liksom och stämmer säkert med originalet. Men satan vilket måndagsex!
Håcke
Inlägg av Håcke »
Alltså...
Jag har ju en sån där och gillar den skarpt!
Men skärbräda...
Jag försökte få tröst av min fru för den jämförelsen,
men fick bara ett rått skratt från henne istället.
Ganska sårad är jag.
Men jag tycker det är snyggt och jag har inget att dölja!
Trögspelad???????
Men vad har du då för strängar?
Min är i stort sett självspelande.
Det räcker att man tar upp den så spelar den själv.
Halsen är grymt skön och väldigt lättspelad.
Det enda negativa är att den är lite tung.
Men man får väl börja träna lite.
Poester
Inlägg av Poester »
Hade en sådan en gång... Skitbra bas, men det aktiva...
Inget för mig!
Tarzan08
Håcke skrev:Alltså...
Men skärbräda...
Hehe... men du har en bra fru.
{fyra strängar}
kravallpolisen
Inlägg av kravallpolisen »
Tarzan08 skrev:Oj!
Jag har en sån här. Kan bara hålla med om att det är en riktigt trevlig bas.
Guild Pilot -85, Strömberg 5, Fender Jazz MM OW
groovyjr
Håcke skrev: Trögspelad???????
Körde DR på min egen och den var justerad precis som jag brukade vilja ha det, ändå var den jobbig/trög att lira på även om det var ett bättre ex ur den synpunkten. Samma har gällt för övriga jag provat även om de inte varit optimalt justerade. Trösgpelad är kanske fel ord, snarare att de varit hårda att spela på precis som det är något mellan stallet och trädelarna som gör att den blir trög eller hård om man så vill. Kan inte förklara det bättre än så men strängarna i rätt stämning var hårda vid fingerspel men till slap om man nu kör det så funkade det utmärkt.
Ja ja, det är ju i övrigt en bra bas och gillar man den så är det bara att tuta och köra!
Tarzan08
[youtube]http://www.youtube.com/watch?v=BA7lMecN ... re=related[/youtube]
spelar skärbräda...
{fyra strängar}
Utte
Inlägg av Utte »
Jag är nog ensam om att tycka att skärbrädelooken tycker jag är underbar! Gillar elektriska instrument utan en färglack över.
Håcke
Inlägg av Håcke »
Tarzan08 skrev: spelar skärbräda...
Kul att se dig in action Tarzan!
Du får väl måla den kanske.
Fortfarande nöjd med min. Och frun.
Gillar ändå färglösheten.
Fast det låter rätt blekt när man säger det.... Och än värre med skärbräda.
Men jag gillar den väldigt mycket. Och färgen.
