Forsterkertopp EBS Classic 500 sendes fra Norge
Fungerer og ser helt perfekt ut. Jeg har bare nrukt det hjemme og max 4 ganger i øvingslokale. Aldri brukt live.
Det er en fantastisk topp men jeg har for mye og må velge å selge noe av dem jeg bruker ikke mer.
Prisen er 5000 NOK + frakt
THE EBS CLASSIC 500 IS THE ANSWER IF YOU'VE BEEN LOOKING FOR AN AMP WITH A SOUND LIKE A TUBE AMP, BUT WITHOUT THE HASSLE AND THE EXTRA WEIGHT A REAL TUBE AMP COMES WITH.
Vintage tone
The alternatives for bass players looking for the warmth and crunch of old-time tube amps are not plenty today. Sure, there are great vintage amps still around but they often come with the baggage of high maintenance costs and plenty of weight to carry around. The one modern amp that we suggest comes ‘as close as you’ll get’ without the mentioned downsides is the EBS Classic 500.
Solid-state power amp
With the solid-state power amp, crunchy organic Drive, and total control over the mid-range through separate Low- and High-mid controls, the Classic 500 is the perfect tool to re-create the sounds of the past, while having the punch of more modern amps as well.
The Classic 500 is pure joy to play!
Input Impedance 1 Mohms
Gain range -oo / +28 dB
Character filter Shelving High/Low Pass
+6 db @ 75 Hz
-2.5 dB @ 800 Hz
+3 dB @ 9 kHz
Tone Controls
Bass Shelving +/- 15 dB @ 100 Hz
Low Mid Sweepable 150-900 Hz +/-15dB, Q=0.9
High Mid Sweepable 1.2-7 kHz +/-15dB, Q=1.1
Treble Shelving +/- 15 dB @ 10 kHz
Drive Section Gain 0-30 dB, Low end compensation
Other Features
Balanced Output,
Line Out
Minimum speaker impedance 2 ohms
Output Power
500 W RMS @ 2 ohms load
440 W RMS @ 4 ohms load
Dimensions (W x D x H) 19.3" x 11.8" x 8.5" (49cm x 30cm x 21,5cm)
Weight 14 kg / 31 lbs
FEATURES
Type: 100% Solid State Amp
EQ section with dual mid controls Boosted drive control
Floating balanced XLR output
500 W output power into 2 ohms
Compact design, fits any ClassicLine cabinet - from the 112 to the 810.
