Begagnad, utan adapter. Finns i midsommarkransen, stockholm. Nypris ca 1500sek mitt pris 1000 sek, kan skickas.
Elevator pitch:
Sculpt your sound with a four-band EQ
The Battalion’s 4-band EQ encompasses the frequencies that are most vital for bass guitarists: Bass affects frequencies below 200Hz, with Lo Mid providing boost/cut at 280Hz. Mid gives you boost/cut at 750Hz, and Treble tackles frequencies above 2kHz.
Inject your bass with extra thump and sustain
If you need more thump and sustain, the Battalion’s compressor is just the ticket. It also evens out your playing, creating a balanced sound that really shines when employing slapping and other dynamic techniques. The compressor features its own push button, amount control, and LED.
Three signal flow modes yield unique tonal variations
Three signal flow modes unlock a plethora of tonal possibilities. In the Pre EQ mode, the distortion section comes after the compressor and before the EQ. The Post EQ mode places the EQ after the compressor and before the distortion. The Dry EQ mode puts the distortion section after the compressor, but only your dry signal is affected by the EQ.
Add growling overdrive to your bass lines
You can achieve an array of distorted bass sounds with the Battalion, thanks to its MOSFET distortion circuit. This circuit’s Level knob sets the output level of your distorted signal, while a Blend knob allows you to control the mix between dry and distorted signals. Crank up the distortion’s intensity with the Drive knob and adjust its high end to taste with the Tone knob.
Electro-Harmonix Battalion Features.
-Preamp and DI pedal for bass guitar
-band EQ with bass guitar-specific frequencies for sculpting your sound
-MOSFET distortion circuit for forging growling overdriven tones
-Compressor injects your bass with extra thump and sustain
-3 signal flow modes unlock a plethora of tonal possibilities
-Noise gate keeps your signal clean
-Flexible I/O ensures easy integration with your rig
EHX battalion DI/pre-amp
- viktro
- snampeg
Re: EHX battalion DI/pre-amp
Hey Victro,
Tar en vild chansning här men undrar om pedalen finns kvar ?
//SN
