Effektloop med möjlighet att blenda via expressionpedal.
https://www.one-control.com/switcher/mo ... gelhUlTbZQ
Kardborre under.
Jag har kört en Darkglass Duality fuzz, Mxr m82 och en Fluxdrive i loopen. Perfekt att kunna blenda in rundgångshelvete i välvalda partier eller lägga filtersvep på enstaka toner.
"The Mosquite Blender Expressio was a direct result of customer feedback. People wanted to be able blend in effects gradually or just be able to have different amounts of saturation throughout a live performance. An expression pedal input was the best solution.
With the original blender, there was only a knob available to control the amount of saturation. With the Expressio you can connect an expression pedal to be able to gradually blend or hands free control your amount of saturation.
Not only that, the Expressio has a built in BJF buffer. So if you were thinking about getting a high quality buffer, you can take out two birds with one stone by purchasing the One Control Mosquite Blender Expressio.
With an amp's Effects Loop
Just like the standard Mosquite Blender, the Expressio version can be used with an effects loop on most amplifiers. Since you have the ability to control the amount of saturation while in front of the amplifier, this is a great tool for fine-tuning your amp's tone during soundcheck or recording sessions.
Without an Expression Pedal
Even though you have the option to blend in effects with the expression pedal input, the Expressio version has a knob also so you can control the amount of saturation just like you would the standard blender. This means for only a bit more than the standard Mosquite blender you can add on expression pedals options and still have all of the same functionality as the normal Mosquite blender.
●9VDC INPUT:As with most pedals, the Expressio takes a standard center negative power supply.
●BLEND KNOB : Use this knob to control the amount of saturation you'd like on your effect.
●INPUT JACK : Connect your cable into this input from instrument or other sound source.
●OUTPUT JACK:After using the Expressio, run a cable out of this jack to go to your next desired amp or effect.
●OUT TO LOOP(SEND):This output will run to desired effect you wish to use with the Expressio.
●IN FROM LOOP(RETURN):The output of the effect will run back into this input.
●POLARITY SWITCH:In case of phase cancelation, use this switch to reverse polarity
●BJF BUFFERSWITCH:Use the switch to control whether or not you'd like the BJF buffer circuit used.
●EXPRESSION PEDAL INPUT:When an expression pedal is connected into this input the knob control is bypassed and saturation control is only controlled by the connected expression pedal.
●FOOT SWITCH:turn on or off the Expressio."
Tänker mej en tusing. 1000kr.
Finns i Uppsala. Besöker Falun ganska ofta, annars går transport att ordna till närliggande orter. Eller frakt efter överenskommelse.
Kan tänka mej att byta mot något annat roligt.
One Control - Mosquite Blender Expressio
- saft
https://orcd.co/urtidsdjur
- saft
Re: One Control - Mosquite Blender Expressio
Bytesförslag! Är på jakt efter bas synth pedal eller flanger. Eventuellt oktav eller chorus.
- Simon
Köper den, skickat PM.
- saft
SÅLD till herren ovan!:)
Lånar tråden lite hoppas det e ok eftersom den redan är såld
Men om någon mer skulle vara intresserad så har jag en exakt likadan till övers som ja kan tänka mig att byta mot nått roligt!
Allt gott!
mvh Alex
Allt gott!
mvh Alex
