Prisidé: 1500 kr (nypris hos tysk nätbutik: 2400 kr)
Köpt ny på Musikbörsen i Kristianstad oktober 2008.
Sparsamt använd som reservmixer.
Kan skickas i originalkartong mot fraktkostnad.
Thomann skriver (på utrikiska):
Behringers produktsida:Behringer Xenyx 1222 FX - 12-channel mixer with 60mm faders,
6 mic inputs with 48V phantom power and 75Hz low cut,
24-bit FX processor,
7-band main EQ,
2 stereo inputs with 3-band EQ,
2 aux sends (pre/post),
USB-PC connection,
peak LED & mute per channel,
2-track in/out,
XLR main out,
separate alt 3-4 out,
internal power supply.
Dimensions: 97 x 345 x 334mm.
Weight: 3.8kg
http://www.behringer.de/EN/Products/1222FX.aspx
![Bild](http://s4.postimage.org/CyKx0.jpg)
![Bild](http://s4.postimage.org/CyPwi.jpg)
![Bild](http://s4.postimage.org/Cz3u9.jpg)
