SÅLD - Phonic MM 1705 (smidig replokalsmixer) - SÅLD
engson
Inlägg av engson »
På grund av mixerbyte med annan pratabasbroder blir denna över.
En Phonic MM 1705
Specar på utrikiska:
Phonic MU1705 Description
MU Series mixers are compact and versatile with 5 to 24 mono Mic/Line and stereo inputs. Ultra low noise pre-amps ensure high quality sound when used in project studios or sound reinforcement. Low-cut filters on mono channels eliminate unwanted sounds like stage rumble, P-pops, wind noise and low frequency recording studio room resonance. The multi-band EQ on every channel gives you maximum control over your mix. The MU series also makes monitoring the mix easy with its dual multi-segment LED level meters and high volume headphone output. The added feature of Mini Stereo I/O makes these mixers perfect for anyone connecting MP3, MD, computer audio or recording devices.
Features
* Five balanced Mic/Line channels, two with channel inserts
* Three stereo Line channels
* 3-band EQ on each channel
* Two stereo AUX returns
* One AUX and 1 Effect Mix Send
* Stereo RCA I/O
* PFL feature on all inputs
* +48V global phantom power
* 60 mm high-quality linear faders
* Dual 13-segment LED level meter
* Two audio groups, balanced
* Stereo main output, balanced
* Mono main output, balanced
Kan skickas i originalkartong, annars finns den utanför Kristianstad, i Skåneland.
Prisidé: ca 1200 kr eller bud/byte. Frakt tillkommer.
Perfekt som replokalsmixer till det lilla bandet!
engson
Inlägg av engson »
Sänkt pris: 1000 kr jämnt inkl frakt.
engson
Inlägg av engson »
Liten mixerbump #2
