Type:All tube
Output:38 watts
Tube Complement: 4 x 6V6 power amp tubes, 3 x ECC83 preamp tubes,1 x GZ34 rectifier tube
Impedance: Switchable 4/8/16 ohms
Channels: Single channel, non master vol.
Connections: Front: Input HI/LO, Back: 2x Speaker Out, Line Out, Footswitch In, Power Controls:Front: Vol., Treble, Mid, Bass, Presence, Back: Line Out Level
Switches: Power, Stand By, Impedance (4/8/16 ohms), Full/Half (Power), Pentode/ Triode, Class AB/Class A
Speaker Configurations: Open back construction with 1 x 12” Celestion Vintage Century & 1 x 12” THC-Neofin by Jensen
Accessories: Power cord, Boost footswitch with cable
Weight: 24 kg (52.9 lbs)
Dimensions 2x12: WHD 760 x 565 x 265 mm (29.92“ x 22.24“ x 10.43“)
Den kostar 36.000 ny och jag ska ha 22.000 för den. Alltså sprillans ny men utan orginalkartong
![Bild](http://i43.photobucket.com/albums/e357/mlaveborn/Till%20salu/sunset_combo212.jpg)
