Jag har fått ett svar från warwick.... Rättare sagt, från ägaren själv. Ja, läs själva vet jag:
Dear Mr. Stockfelt,
at first I am really unhappy or disappointed to see this problem happen on a
Bass
from us and I am as the owner of warwick just out of words that such a mistake
happen.....
This is purely our fault and I cannot give you enough excuses that we didn´t
care
enough to give you a perfect product...
Yes, the 2 Dot inlays between the 25 and 26 Frett are completelly wrong and
shouldn`t
be on this position...
To solve this problem for you we have only the solution, to take the Bass Bag to
Germany
and to repair the mistake.. we would take out the wrong dot inlays, fill it up
with some
wenge wood so that you nearly can`t see it anymore and seconde, we have to drill
in the
2 dots on the correct position...
Now the question is, do you have the possibility to pack the Bass carefully and
to send
it by Post back to us in Germany so that we can repair it.. of cours we would
cover the
shipping costs you would have with it..., after the Bass is repaired, we would
send
it back to you again.
Please let us know what you like to do from your side....
The other possibility would be, that you accept the mistake and we wouls end you
a
Warwick 25 Anniversary Leather Jacket free of charge over to you as a small
settlement
for this mistake...
Please let us know what you prefere... !
Once again, we are very sorry for this unacceptable mistake and I am looking
forward
to hear from you again.
with best regards
Singapore Airport
H.P.Wilfer 10.07.2007, 22:40
Väldigt sympatiskt måste jag säga! Underbart!
Sååå.... vad ska man göra? Få en fet läderjacka gratis eller böka sig med att packa in en bas och skicka till tyskland för att fixa ett fel som man inte egentligen stör sig så mycket på? Känner mig allt mer nöjd med mitt inköp...
Du kan antingen få den fixad och ha en helt vanlig (om än väldigt trevlig) bas.
Eller du kan ha en one-off jacka, en 2-shilling banco-bas som fortfarande är minst lika trevlig, och en kul (och dokumenterad) historia att backa upp med.
Jag fick då fan ingen jacka när deras 110 volts topp sa poff i mina händer, däremot tyckte den feta gubben som jobbar på Flaa att jag var gnällig när jag tog upp det med honom...
GrafZeppelin skrev:Jag fick då fan ingen jacka när deras 110 volts topp sa poff i mina händer, däremot tyckte den feta gubben som jobbar på Flaa att jag var gnällig när jag tog upp det med honom...
Du tog upp det med den fete svensken, inte den hjälpsamma tyske ägaren.
