Aguilar DB750 + DB810 (The WreckingWall)
- Liten
Ja då var det dax..
Efter gårdagens 4timmars rep så tänkte jag dela med mig lite av vad jag vill börja med att beskriva som en euforisk upplevelse..
Vad är det för något jag recenserar??
Formalia:
Förstärkare: Aguilar DB750
Specs:
Accepts 2, 4, and 8 ohm loads
Tuner Out with Mute
Self-Diagnostic Protection Circuit and Thermal Overload Protection Circuit (both with LED Indicators)
Short Circuit Protection
Power Output: 750 watts @ 4 ohms, 975 watts @ 2 ohms. (conservatively rated)
Preamp Section: Three 12AX7s and one 12AU7
Power Section: 12 complimentary lateral MOSFETs
Transformers: Custom Aguilar toroidal power transformer.
EQ Section: Tube-driven shelving type treble (+/ - 12dB @4kHz), mid (+/ - 12dB @ 400Hz), and bass (+/ - 12dB @ 40Hz) controls.
Deep Switch: Adds 3db of broad-band boost at 30 Hz.
Bright Switch: A passive RC pre-emphasis circuit at 5-7 kHz.
Effects Loop: Send pot is push/pull for line or instrument level; return pot is push/pull for parallel or series operation.
Inputs: One 1/4" input jack with an active/passive switch. One 1/4" power amp input.
Outputs: Two Neutrik Speakon speaker outputs, one Jenson XLR balanced output (-32dB pre- and post-EQ) with a ground lift switch, and one 1/4" jack preamp output.
Cooling: High quality whisper fan
Power Requirement: 100, 120, 230 VAC 50 - 60 Hz
Dimensions: 19" W x 14" D x 5.25" H
Rack Size: Three Spaces
Weight: 43 lbs
Låda: Aguilar DB810
Specs:
Eight 10" cast frame woofers, 56 oz. magnet
Phenolic tweeter with integral phase plug
Custom crossover with variable tweeter control
One Neutrik Speakon and two 1/4" inputs
Tilt-back handles and rear wheels
Power Handling: 1400 watts RMS
Impedance: 4 ohms
Frequency Response: 40 Hz - 16 kHz
Sensitivity: 104 dB 1W 1M
Max SPL: 136 dB
13 ply Baltic Birch
Dimensions: 46" H, 24 1/2" W, 18" D
Weight: 184 lbs
Warranty: 3 year limited
Att rodda:
Jag var orolig att lådan skulle vara för stor och tung..
Till min förvåning gick den utan problem in i baksätet på min bil.. det känns utan tvekan som om grabbaran på Aguilar tänkt till på formatet.
Det var inga problem att få runt den i den smala trappen upp på övervåningen i replokalshuset heller..
Tack vare ett nytt case till toppen så känns den nu väldigt smidig.. jag bär lätt topp och mina basar i dubbelcase i varsin hand..
Riggen är avsevärt mindre än Sunn-riggen jag hade tidigare.. det innebär dock inte att den låter mindre..
In action:
Jag baserar denna recension på 2 faser.. en på vansinnig repvolym med hörselproppar och en på låg repvolym utan proppar...
Fas 1: (VM i volym..)
Min plan var att sätta en fast volym som gav mig "volume-headroom" och sedan justera med anslag alternativt volym på basen.. sagt och gjort.. min nuvarande och framtida volym är "12'o'clock" på allt! HELT rakt(flat) på alla reglage..
Det tog några minuter för båda mina medmusikanter att vänja sig vid de nya freqvenserna som jag tar upp.. till skillnad från förut..
För att ni skall förstå vilken volym vi pratar om när riggen går på "halvfart" så fick både trummisen och jag skaka av våra jackor när vi lämnade lokalen.. småbitar från takpanelen hade flagnat av och låg som ett tunnt täcke på luvorna....
På en skala från 1 till 10 så ska jag försöka ge en bild av vart Aguilar-riggen ligger genom att placera ut min tidigare rigg i samma skala..
Om jag ger Aguilaren max, dvs 10.. så ligger Sunn-riggen på mellan 4 och 5.. onyanserad och "ny-kär" recension?? nope..
Jag har ALDRIG spelat på en så Oförlåtande rigg i hela mitt liv.. minsta lilla blurr, minsta uns av sloppyness hörs till lokalen på våningen under..
För att citera trummisen som utbrast efter en stund: Det låter ju som om du suttit hemma och övat!
Som ett formulär med tvingande fält så tvingas man till att spela på topp hela tiden.. ALLT hörs.. ALLT!
Fas 2: Hur låter den då.. på riktigt...
Jag var även orolig för att jag skulle sakna tonen och det där som vi har så svårt för att definiera med rörsträkare.. jag brukar kalla det för gummisnodd-sound.. men icke.. På låg volym så fyllde den ut soundet på samma sätt som många förknippar med rör-förstärkare.. den behåller dock en mycket mer fokuserad ton och klippet.. klippet... SHIT POMMES! säger jag bara..
Jag vill påstå att detta även är den cleanaste förstärkare jag spelat på..
Alla reglage raka och båda mina basar låter TOTALT olika genom den trots samma preamp i basarna.. detta har aldrig varit så tydligt på mina tidigare riggar...
Jag ser fram emot era reaktioner under PB-dagarna i April.. hur ni upplever att just er bas låter genom denna..
Riktiga bilder på riggen kommer på Lördag.
EDIT1: Vill tillägga att jag "avbeställt" DB115 lådan hos Mattisson.. förefaller helt meningslöst att köpa den av 2 anledningar.
1. Den kommer aldrig behövas rent musikaliskt..
2. Jag kommer aldrig vilja spela utan 810:an och då infaller punkt 1 igen.
EDIT2: Revidering av EDIT1.. DB115 nu inhandlad.. varför? 810:an kände sig ensam...
Formalia:
Specs:
Tuner Out with Mute
Weight: 43 lbs
Låda: Aguilar DB810
Specs:
Impedance: 4 ohms
Max SPL: 136 dB
13 ply Baltic Birch
Weight: 184 lbs
Att rodda:
In action:
- Liten
Den går att överstyra.. men väldigt lite.. om man jämför med min tidigare rigg.. nyckelordet för riggen är CLEAN.. något jag har eftersträvat rent ljudmässigt...Danne skrev:Får gratulera till vad som helt klart verkar vara en grym rigg. En riktig referensrigg mao. Är det skön dist om man kranar på försteget eller är den mest anpassad för ett rent ljud?
För OD så kör jag en Moollon padda.. lät riktigt bra men för första gången så hörde jag hur den kapade headroom.. dynamiken ändrades hörbart.. vilket kanske är något som OD's borde göra?
- Diesel
- basmartin
Grattis, återigen!
- Diesel
- Liten
- Svarte_Jack
Får man in den i en ford fiesta ?
http://myspace.com/steglers
- Liten
Ford fiesta får du in vilken basrigg som helst i..Svarte_Jack skrev:Får man in den i en ford fiesta ?
Denna är ju mindre än den jag hade tidigare.. och den jag hade tidigare hämtade jag i en ford fiesta.. fiesta är en djävla lastbil!!! grym!
- Svarte_Jack
HAHA!!!
Bytes:
Ford fiesta mot husbil.
Bytes:
- Liten
- basmartin
Hur låter Sunn-toppen i Aguilarlådan, förresten?
- Liten
...vet inte varför jag ska prova heller...
Vi får väl testa i april om ni tjatar så.....
Mycket bra fråga!basmartin skrev:Hur låter Sunn-toppen i Aguilarlådan, förresten?
Vilken vi vill ha svar på omgående, men visst, vi kan vänta till April om du inte vågar jämföra själv Liten....
- Liten
Testar på torsdag då...
Tror att det kommer låta ganska lika.. något mindre definition men kanske något mer "OD" i soundet från sunnen..
BTW: Spelade in för första gången med DB750'n i Söndags.. direkt från balanced out med post eq..
Ringde Mattisson då jag inte fick ut något sound med post eq.. det visade sig att det var skit bakom spakarna..
Tyvärr spelade jag som en säck potatis och la ner efter ett tag... men det soundet som landade på spåren kändes bra mycket tydligare och bättre än tidigare inspelningar.. körde basen helt passiv och eq:n på stärken ganska flat.. lite boost på bas och mid för att kompensera för avslagna preampen i basen.. Bara halsmicken.. bra med fläsk och mycket definition... trabajó muy muy bien!!
- JMP
- Liten
Tack.. den låter bättre än den ser ut!JMP skrev:Måste bara säga......skitsnygg!!!
- JMP
- criss
jag testade min gamla bassman135 topp i en sån låda - det lät jävligt bra!basmartin skrev:Hur låter Sunn-toppen i Aguilarlådan, förresten?
R.I.P Jr Eric
- criss
var det på musikhögskolan?Liten skrev:Testar på torsdag då...
jag mötte isf anders precis utanför....ja, det var ju intressant för alla att veta
R.I.P Jr Eric
